gil7247
I don't know about the other but BNL puts on a great show I've seen them 3 times and each one was great, Stay Dry!!
super1c said:Got the first tunnel installed! When together without a problem. Everything seemed to rivet together nice and true. I know a lot of people had problems getting the hose covers to line up but they seemed to go right together fine. I really like the mtn apex bumper, and the nyto tail light and i have a nytro red snowflap. Tail light not mounted yet waiting to order boss seat first for position. The only thing im upset about it the bleed screw plug for the bleed hole. On my mtn viper cooler the screw part is raised and the plug wont fit. Did i do somthing wrong? Any tips to get that to fit right. If not im just going to silicone it in place. Then easy to remove it i have to bleed. Some pics of what im talking about and the whole tunnel.
gil7247 said:I don't know about the other but BNL puts on a great show I've seen them 3 times and each one was great, Stay Dry!!
gil7247 said:You wouldn't think if both track are the same brand / model they would be very different in length. How much tighter was it then your sled? Could there be some difference in the sled since they are different years? Strange problem. It looks good though!
snoprokidf6 said:Not all parts are "exactly" the same. One set of rail extensions could have been a hair longer, or the track a touch shorter.
As for track break in, I set my cobra as loose as possible w/o slipping on the cogs. Rode like I normally would and checked every 100 miles/every ride. I had to tighten a few times because it is a softer rubber when compared to the ripsaw so it did stretch a bit more but no more than a usual track. Good choice with the cobra, you'll love it!
amatosrx said:Did u get a 120 inch long track.
musselman said:The 136 cobra I got was a little tight when new but 1000 miles it has stretched out nice. As long as you can get it on, it will be fine.
Everything looks good by the way, you are doing a lot better than me lol.
